I've also tried doing a search for the error message "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
I did a search for "Vista" along with the above text, and got to this site:
http://www.vistax64.com/vista-hardware-dev...ot-working.html
They've got some things at the end that sound possible, but very complicated (to me). Here's the text, copied from the above site:
From Microsoft.... this takes about 5 minutes to do...
Method 2: Manually delete the registry entries
Important This article contains information about how to modify the
registry. Make sure that you back up the registry before you modify it. Make
sure that you know how to restore the registry if a problem occurs. For more
information about how to back up, restore, and modify the registry, click the
following article number to view the article in the Microsoft Knowledge Base:
256986 (http://support.microsoft.com/kb/256986/) Description of the
Microsoft Windows registry
Warning Serious problems might occur if you modify the registry incorrectly
by using Registry Editor or by using another method. These problems might
require that you reinstall the operating system. Microsoft cannot guarantee
that these problems can be solved. Modify the registry at your own risk.Log
on to Windows by using an account that has administrator rights and
permissions. Then, follow these steps.
Step 1: Start Registry Editor
Click Start, click Run, type regedit, and then click OK. Registry Editor
starts.
Step 2: Delete the UpperFilters registry entry
1. In Registry Editor, expand My Computer, and then expand
HKEY_LOCAL_MACHINE.
2. Expand SYSTEM, and then expand CurrentControlSet.
3. Expand Control, and then expand Class.
4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the
UpperFilters registry entry, you must click UpperFilters and not
UpperFilters.bak.
6. On the Edit menu, click Delete.
7. When you receive the following message, click Yes to confirm the deletion
of the UpperFilters registry entry:
Are you sure you want to delete this value?
The UpperFilters registry entry is removed from the
{4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next
step.
Step 3: Delete the LowerFilters registry entry
HKEY_LOCAL_MACHINE.
5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the
LowerFilters registry entry, you must click LowerFilters and not
LowerFilters.bak.
of the LowerFilters registry entry:
The LowerFilters registry entry is removed from the
8. Exit Registry Editor.
Step 4: Restart the computer
If a CD recording program no longer works after you restart the computer,
you must reinstall the CD recording program.
Back to the top
