I have ccleaner installed and have used it many times, now when I try to open it, it just flashes and closes.
What happened? how can I fix this?
Thanks!
Thanks!
I think the first thing to check may be the setting you have under options>advanced for 'close program after cleaning'
I checked that, the box is not checked to close after cleaning.
Try following the thread here in case you have any malware.
