Help with build of winnap2.ini
I want this:
Add a entrie to winnap2.ini that do:
Clean all the folders and subfolders in: In exception of amsn@hotmail.com on:
C:\Documents and Settings\Fam?lia Luik\Contacts\
C:\Documents and Settings\Fam?lia Luik\Dados de aplicativos\Screenshot Sender\
C:\Documents and Settings\Fam?lia Luik\Configura??es locais\Dados de aplicativos\Microsoft\Messenger\
C:\Documents and Settings\Fam?lia Luik\Configura??es locais\Dados de aplicativos\Microsoft\Windows Live Contacts\
Is possible? Can someone help me???
Thanks!!!
Is possible??? :blink:
HELP ME PLEASE!!!
No one know how???
Say anything!
Hi luik, it doesn't look like you're getting many takers, and I can't help you with a winnap2.ini file, but in the meantime, have you not tried adding those folders to CCleaners "Include" option. (Options > Include > Add Folder). And check "custom files and folders" in the advanced section.
Unless I'm missing something, I don't see why that shouldn't work. If there's a file or sub folder in there you want to keep, add that to CCleaners "Exclude > Add Folder/File".
I'm not sure if you can "exclude" a file/folder within folders you "include", maybe someone can confirm that either way.
Hey!!! It works!!!
Thanks a lot!
