help with "autoclean".
does anyone know how i can get ccleaner to clean automaticly at the startup of the program?
i'm planning to clean my computer with a batch file. so i need to make ccleaner clean the computer when i'm running the batch file! can anyone help me?
(i'm norwigian so sorry if my english suck... :P )
Hello hernil, nice to see you on the forum :)
There is some info here you may like to read
http://forum.ccleaner.com/index.php?showto...5533;entry38222
thanks a lot! worked perfectly! :D
you shuoldn't happend to know how i can do something similar with norton antivirus? (scanning the computer by running the batch file?)
I don't know the answer to that hernil, but I am sure there may be some people here on the forum who do.
do you know a better place to start a topic about that subject than here?
btw: is there any way to see the progress after ccleaner has cleaned my computer?
bumping this tread before it dies a silent deth!
No because the /AUTO parameter doesn't load the GUI or save any logs for later inspection. It only runs what's listed and selected in the large Cleaner button area, it won't run the Issues scanner at all when using /AUTO.
ok, thanks. but is there another command that does that?
Currently no, however you can always submit it as a feature request/suggestion by making a new thread in:
http://forum.ccleaner.com/index.php?showforum=14
thanks I'll try that.
do you know if ccleaner makes any logfile when it's finish cleaning? if yes, where?
No it doesn't create any cleaning logs. The only possible creation of any files by CCleaner after installation is when using the Issues button, it offers to make a backup of the removed registry issues.
