4. User finds Recuva, downloads, installs and attempts to recovery.
On the front page, the user should be warned that down loading and executing will likely destroy their ability to recover the subject files.
In the rush to 'sell', the requirement to protect the user from actions you know will destroy their data, has been ... neglected.
After warning the user of this folly, the next statement should be exactly what they need to do to best support their immediate need - not your need to sell.
by the time the user gets the warning from Piriform that downloading Recuva may decrease your recovery chances, the mere fact the PC in question is in use and searching the web is already reducing your chances.
not to mention the myriad of background process in use that are potentially accessing the drive.
but some things cannot be avoided.
I couldn't see anywhere on the Piriform site, from general browsing their products available, to each specific page for a particular product, to the download pages, where the Free version wasn't promoted first and the Pro version offered right next to it.
Where I see in some of the posts on this topic, the paid version is used.
The user downloads the free version and breaks their ability to recovery.
They pay for what they hope is a better tool and break it some more.
The users should be protected from themselves.
Piriform knows the problem and chooses not to be informative.
Yes, there are many ways a user can allow their system to further fracture; that is not an excuse to continue neglecting to provide the appropriate information up front.
Unfortunately by the time the user has reached step 4 (in the original post) the damage has already been done, as Piriform explains. Searching for a recovery method involves many pages of hits on Google, looking at various reviews, how-to's and comments, and probably browsing forums such as this. So by the time the use choses Recuva - or any recovery software - he or she has overwritten several hundred or more entries in the MFT and just as many or even more clusters.
Whilst recovery software could say that for the best chance of recovery download and install the software to another drive, by the time you get there you've already done the damage, especially if the recovery is on the system drive, where most of the hits take place.
Yes, this would be really nice to know before hand. If the program will destroy chances of recovery, i would not do it. Perhaps trying another recovery program has already ruined it. Some of the programs indicate that the user should make an image of the drive - of course, that is quite impossible because the system does not recognize the drive at all, let alone image it.
I have made the apparently erroneous assumption that the program only reads the data and takes information into memory until it is convinced that the data is there, then rewrites the indices etc. It would make more sense to leave the drive unmodified. Show the user what data it has and ask the user to identify whether or not the data is correct. In other words, if a file is located and it is unknown if it is the right one, ask the user, allow the user to recover it and try it to determine whether it has actually been recovered.
Assume that undeleted files are the files that are desired unless expressly told differently. That is, perhaps interrogation of the user before starting and a little info about what the decision that has to be made will entail for each possible choice is appropriate.
