HELP: Recuva64 started from USB can not recover
I have installed the portable Recuva on a USB stick.
Started the crash system and went to the command prompt.
The USB Stick is the D: drive.
So I started Recuva64 from the D:\Recuva\
It found the files on C:?\ which I was looking for.
I selected the files and when I select recover the pop-up window does not find a location to store the files and also the button Make new folder does nothing.
So, what did I do wrong and why can I not recover these files to the USB drive D:?
Recuva_log1_51_1063 (64-bit)11-1-2015_21-48.txt
Closed. You only need one thread and the one in bug reports is more appropriately placed
