Hi I just deleted some useful info and now I need it back, any way to get it back?
For recovering data it's best to act fast. First get a small external drive (with free space enough to hold the data you need)
Next (preferably on a different computer from the one with data lost if possible) download to the external drive recuva portable (from the parent site of this forum)
http://www.piriform.com/recuva/builds
Extract the zip file contents to the external
If you did these steps on another computer, now is the time to plug the external into the computer with the lost data.
Run the recuva exe directly off the external drive.
I've taken the liberty of moving this thread to the recuva discussion board where we will be provide you with continued aid if needed.
I will private message you a link to the new location in case you can't find it.
Until you recover the data you MUST USE THE EFFECTED PC AS LITTLE AS POSSIBLE in order to maximize your chances of successfully recovering.
