wipes out my most recently saved 'favorites' in Firefox and I.E. after a cleaning.
Can someone please advise me what to uncheck so that I don't have to export my faves, run CC and then re import the favorites back into the browser? Thank you (believe it or not I have read all the help files first and haven't found an answer to this :-)
First, try the current version 2.22.968. It may be a bug that's been fixed.
Thanks Glenn. I'll give it a try. The funny thing is it's a relatively new problem although I've used the current version of CC for years without any issues. That's why I never upgraded (call it the Microsoft Syndrome Upgrade anything those maniacs make at your own peril....)
Any chance it's a cookie setting I need to change?
Although I've skipped a few updates, I've used most of the 2.xx versions of CCleaner with no problems of any sort. With the default settings, I haven't had any problems with IE6, IE7 or IE8 (although I no longer use the latter) on Windows XP.
