well i have accidentally deleted the Boot Execute in windows registry....and now it is saying "autocheck.exe was not found skipping autocheck" unfortunately i have no back up of that value...so if anyone knows how to solve this problem pls tell me...
still no luck on that link...
You could try merging the below into your registry.
Windows Registry Editor Version 5.00[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Session Manager]"BootExecute"=hex(7):61,00,75,00,74,00,6f,00,63,00,68,00,65,00,63,00,6b,00,20,\ 00,61,00,75,00,74,00,6f,00,63,00,68,00,6b,00,20,00,2a,00,00,00,00,00
thanks Humpty i'll try this one out
System Restore may help at boot # 1 Safemode with a Command Prompt # 2 Pick Administrator Account # 3 At the command prompt type %systemroot%\system32\restore\rstrui.exe # 4Follow the instructions to restore you PC to Earlier State of operation
What's with the replying to old posts all the time?
