Hi all, some help is needed please, I just run CCleaner and it appears to have erased some pics ( I think, I cannot find them anywhere )is there any way to recover them, I run cleaner before running analyse, any help appreciated, thanks.
Possibly Recuva can find them. If you were by chance storing them in a Temp folder I'd recommend using the My Documents folder which CCleaner doesn't touch.
