Help me : Recovery file deleted
First of all I apologize for my English but I am Italian.
I have a problem, I need to recover deleted files on a USB memory card.
The program found many files but it says it will be ignored, why?
how do I retrieve every file? The program shows me only a few files than the ones it finds. Thank you all.
Switch to Advanced mode - button in top left hand corner. Select Options Actions. Check the top three boxes.
Passare alla modalità avanzata - pulsante in alto a sinistra mano. Selezionare Opzioni Azioni. Controllare le prime tre caselle.
As you have Recuva Professional you should contact your support manager for assistance.
Come avete Recuva professionale è necessario contattare il gestore di sostegno per l'assistenza.
thank you I'll try
