can anyone here push a good hyperlink to me so that i can understand all of the terms used inside of the CCleaner main tabs? for instance, i know what a "fetch" is, but what is an old prefetch? how old would that be? is there a way to learn about cleaning various items that i do not have a knowledge of? any discussions anywhere? thanks!
Hi techie gal.
Have a read of the CCleaner documents HERE:
And the old CCleaner Beginners Guide HERE:
The second one is a direct download link which we normally don't like to post, but in this case it's the only way I know to get hold of the old guide, which is still pretty informative.
Post back if you need more help, and of course give google a try for things like "Prefetch". You'll always get something useful from google.
Hope that helps.
