Help! I really messed up!
It is good to see you survived your mini disaster.
“The person that made no mistakes learns nothing.”
I have put a useful address at the bottom of this post for you.
Here is some helpful basic rules to keep you out of trouble in future :
NEVER NEVER delete files, programs or mails when tired because that is where 90% of PC accidents happen.
It can wait until the morning.
NEVER delete something if you do not know what it is ~ go learn about what that file or program does first to see if it is safe to remove.
NEVER assume that your CC settings will react the same on another persons system because all systems have not got the same settings or programs etc.
NEVER mess about with Reg cleaners or Reg fixers unless you know exactly what every file does that you want to delete and if the Reg program you are using works or can be trusted. Personally I do not know anybody that has trusted a Reg fix Program and there are many Reg software packages available. I use only CC on a limited basis for this operation.
NEVER run downloaded .exe files you do not know because they can be Viruses waiting for you to open them.
(The Virus lay dormant until it's .exe file is opened)
Again it cannot be stressed enough no matter how good you are with PC’s ~ NEVER NEVER NEVER delete files or programs or mail when tired because that is where 90% of PC Accidents Happen.
BE SAFE :
Always Read it Before you Delete it or install it
We all have hard lessons at some point and this time you got lucky. CC can do a lot of damage if you are not careful so read the help files at this site to see what all the options do.
http://docs.piriform.com/ccleaner/ccleaner...-explorer-files
Yeah.....A success!!!!!!!!!!!!
Well done motley. You did good.
Hi motley.
From what you say above about getting the infamous screen over again, is I think as far as you'll get with any of those options.
I've experienced just that situation, and you're in a reboot loop.
I've a suggestion for you which will enable you to either fix the PC by replacing the 5 registry files as explained above, which honestly isn't very difficult if you take your time, or which will enable you to get all personal data off that PC.
I'm pm'ing you with a link to a rescue program I keep stored online. All you have to do is download it onto another PC, extract the single ISO file from the zip file it's in, and then burn it to CD using an "Image" burning software.
Two free ones are ImgBurn, and Ashampoo Burning Studio.
If you're gonna go ahead with this, I've gone through some of the rescue process with this program, and I'll guide you through it with photographs I took while doing it.
Apart from anything else, it would be an educational experience which you could use with any future mishaps. Hopefully that would never happen.
Let me know if you download the ISO and need any advice on burning it to a CD. It has to be burned as an Image, and not just copied. Quite easy.
I'm having the same problem. Could you post the link to the rescue program?
I'll pm you.
I'll pm you.
Dennis: I thought that evertything worked out so kool, that I would try the recovery disk in another computer that had similar issues but the owner (another dghtr) went and bought another computer instead.
I do't remember just what the issue was; just could not get on but not sure how far got on. Anyways, the computer takes the disc but then when the screen comes up to choose C:/WINDOWS or (none), I cannot move the the cursor to click on anything. Mouse does not work and it seems the keyboard does not either. Does this mean give it up? When the computer/laptop powers on, the scroll light flashes and so a light next to caps lock key (which is also above the expansion port 2). Probably out of luck but it was exciting to think, as the disk was loading, that I may have gotten a computer out of the deal!
Monkey: I have passed on the 90% of problems from deleting when tired to a bunch of people. Nice info.
Is it a USB mouse and Keyboard ?
Happy to be of some use motley.
It is common as hell for this to happen and it is very easily done. Any system management should only be carried out when we are wide awake and have a good time slot to deal with it.
If you get into areas you are unfamiliar with then call a friend that may be able to help and always cross reference any info at least three times from different sources to verify (Wiki is a dubious source of information and should not be trusted when doing research).
We have all done something stupid at some point with our PC’s but the best cure is usually avoidance.
It is a laptop/notebook. I did, however try a USB mouns but nothing.
Sorry motley, offhand I have no idea what the answer is to that one. Would pressing return not do anything? I'm thinking one of the choices may be active by default until you change it, and pressing return may work.
Apart from that, I have no idea as I've never encountered that situation.
Maybe try a different rescue CD. Here are a couple of links to AntiMalware Rescue CD's. You burn them as Images as before, and they boot the PC and give you the opportunity to scan for malware, which may be the cause of the problem.
DrWeb Rescue CD:
Avira Rescue CD:
Good luck with it.
EDIT: There's actually a list of different rescue disks down the page of the Dr Web link.
I have come across the same problem with USB keyboards and mice not responding on bootup. Sometimes it is because the PC does not see them until after the bootup. If the PC can’t see it there will be no response when you press a key or click the button before you get to the account login page for password etc. It only happens with some models of mouse and keyboard.
Maybe the motherboard model is doing this also ?
That does not explain your laptop keyboard error sorry. I don't play with laptops so I can't really say what your solution is.
You could try an external keyboard and a standard mouse connector instead of a USB type to see if it responds.
In a Worse Case Scenario = If you don’t care about the files on the laptop and just want to get it working then you could always just format the drive, then you can start from scratch with a clean system.
You will need a copy of windows to install on the drive once you have wiped it clean though.
The same Windows Serial No. if using a copy could be a problem for you depending on if you want to take it online for say MS Windows updates.
If it is just a problem caused by software it will be repairable one way or another.
If it is a hardware problem you may still be able to fix it but it could just be kaputt.
Has it had water damage or been dropped etc. ?
I have come across the same problem with USB keyboards and mice not responding on bootup. Sometimes it is because the PC does not see them until after the bootup. If the PC can?t see it there will be no response when you press a key or click the button before you get to the account login page for password etc. It only happens with some models of mouse and keyboard.
In a Worse Case Scenario = If you don?t care about the files on the laptop and just want to get it working then you could always just format the drive, then you can start from scratch with a clean system.
If it is a hardware problem you may still be able to fix it but it could just be kaput.
[/quote
I could care less about the files....just liked the idea of a free computer since the owner has already counted it as obsolete. Could I format the drive (however you do that) with linux. I have a computer that can boot in both microsoft and linux and I wouldn't mind linux if it meant free laptop.
Try to rescue it first so that you can keep the original OP serial No. if it is a legit OP that is ?
First try the keyboard from your PC, if the laptop has a port that will take it, and try a mouse that has a standard din socket connector as appose to a USB type. That may solve your problem also.
Patience is the key so try it, if it does not work and all else fails you could wipe the Ltop drive Via your PC. Windows has instructions for formatting HD?s somewhere but be sure it is the right HD you format :lol:
Wait to see what people post here because they may have better knowledge about this particular problem you have encountered. The solution could be a simple one.
Nice score on the laptop though ~ free is my favourite price tag also, mostly :lol:
