just now i enter Tools->Drive Wiper in order to wipe free space, unfortunately, i select "Entire Drive (all data will be erased)" in Wipe option, "Simple Overwrite (1 pass)" in Security option, and "drive C,D,E,F" in Drives option. at last, i found all the data in all the drives are deleted!!!!
oh, my god! all the data is related to my work. if i lose it, my boss will kill me!!!
please kindly teach me how to find back the deleted data???
You wouldn't be able to wipe drive C: if it was the drive where Windows was installed.
As for the other drives I wish you good luck undoing any secure deletion because you'll seriously need it since it will be virtually impossible! You could try Recuva and see if it can find anything, but I doubt it will.
I have tried Recuva and find a lot of files, but when i open the files, it says "The file may be unsupported, damaged or corrupted."
Getting things like "Unsupported, Corrupt" etc., in programs that would normally restore a deleted file would mean it's most likely completely unrecoverable since it was after all secure deleted, and CCleaner's 1-pass wipe technique is beyond extremely good at what it does!
My main question is why would "the boss" if it's his company computer allow any software on it including CCleaner that has the potential to be abused and irreversible wipe/secure delete production data. This topic really is somewhat strange to me.
**removes moderator hat** wow ummmm Domain Admins and I.T. people THIS IS WHY YOU DON'T LET Your employees use unknown products
**replaces moderator hat**
Where are the backups? Any competent organization will have some sort of backup plan in place.. If there are none, then this *could* be a lesson for making them in the future.
My experience is it takes a major screw-up (or several minor ones) to get a backup plan instituted.
And furthermore, It seems CCleaner has a few steps you have deliberately to go through in order to get the drive erased, first is getting into the menu with the drive wipe options, second is changing the option to do so, then selecting the drive(s), then having to type "ERASE". And clicking ok. In addition there is warning text.
