[Help] How clear WoW cache folder
Hello, i was wondering if there is somthing i can do to get CCleaner to clear the cache folder in my world of warcraft directory.
Now i already did this :
http://i250.photobucket.com/albums/gg252/d...Untitled-12.jpg
so that it clears out wat is in the folder
but is there a way to get it 2 just delete the Whole cache folder instead of cleaning it out?
plz help
if im correct i need one of those winapp.ini
if so can someone plz help me make one?
Hi RunBatFile, and welcome to the forum.
A nice workaround for that was posted by Augeas recently:
http://forum.piriform.com/index.php?s=&amp...st&p=124249
Hope that helps.
Hope that helps.
thanks man that worked for me
you tech and mod guys really know your Stuff!!
thanks a million
