I would like to know if there is some way to increase the size of the font in the program. Being vision impaired it's very difficult to read the results in the fields, and through out the program. any suggestions would be wellcome.
from within CC itself there is not, but there is the other 2 usual ways.
if you have Windows, you can use the Magnifier or you can increase the font size of the system fonts in Control Panel, Display.
