Help finding file
I have just installed ERUNT registry restorer after reading about it here. I have backed up my registry in the fileC//WINDOWS//ERDNT//14-05-2009 which is the default setting and where I will have to visit to execute a restore. The problem is I can't find it. Can anyone please explain how I access this file.
Regards Alex.
To restore the registry from for example your backup you've listed you'd run the ERDNT.exe file from your backup folder. The full path (just use Start->Run):
C:\WINDOWS\ERDNT\14-05-2009\ERDNT.exe
