Help defraggler wont defrag selected files
I did see a post similar to this but did not know what i should do on my computer.
Pretty much i noticed a sever slowdown in my computers performance and alot of space was taken up that i couldnt find. I recently reloaded vista on it about a week or two ago. I try defragging and it wont defrag these files. I was hoping someone could help me do that. Thanks in advance :]
These are my specs (if its needed):
http://tinypic.com/r/2v8is6c/7
These are the files that wont defrag after analyzing, checking all and defragging selected, then analyzing again.:
http://tinypic.com/r/2n682mb/7
Again, thanks in advance for any help.
The first ones are System Restore Points. They cannot be defragged (and anyway defragging them would be pointless since they are hardly used). Enabled system files/folders view in Windows Explorer, then add C:\System Volume Information\ to Defraggler's Exclude list.
Pagefile.sys is the page file. It can only be defragged in a boot-time defrag, which is a feature planned for Defraggler 2.
If you are sure there is currently nothing wrong with your computer, you can do the following:
