help ccleaner
OK I downloaded ccleaner , when I try to use it nothing happens. I am running XP sp1. Can Anyone Help!!!!!
Try it again. Sometimes when you first intall ccleaner it does not work... or either un-install ccleaner - then re-install. to try get it working... Also if your windows is Legal install Service pack 2...! It's Massive update towards Windows xp. Security wise, and patching...
gamegrl follow this link to get ccleaner running:
http://forum.ccleaner.com/index.php?showtopic=1192
