Under the "menu" for CCleaner if you scroll down to "advanced" what is menu order cache? in simple terms please. Thanks
Im not quite sure, but i believe window's cache's (saves) the order of your start menu items so they stay the same for the next time you start your pc. CCleaner deletes the cache NOT THE ACTUAL START MENU ITEMS so there is no record of what was in your start menu. I think
P.S. Im more then likely completely wrong but hay there you go, i tried.
From that link "Menu Order Cache
The Start menu allows you to set a custom order to the programs listed, although there's no option to sort all folders by name. Selecting this option removes any custom ordering from the Start menu." Yaaa its more or less what i said
Thanks each
