Heat processor
If you run the program it will raise the processor temperature
:unsure:
G’day @azohm11 and welcome to the forums.
what are your temperatures?
are you finding them unusually high?
hi .The temperature is always 22 - 24
But Speccy rises to 35
22-24 is amazing and 35 is great as well.
any running process, crunching numbers, will put the CPU under load and therefore raise the heat eventually.
remove the load, the heat reduces.
so while 35 is nothing to worry about, the increase can be pinpointed at Speccy and its continually polling of the WMI service to get the details it has to display.
There is no running process except that the Speccy is the one that raises the heat
Thanks for the help
