When I run the health check the speed and security sections says I am offline. I have CCleaner Pro, shouldn't that run also. By the way I am online when I run the software.
The offline message in Health Check is missleading. It means that the servers cannot be contacted to check for software updates, etc. Not that you are offline - we are told that it will be reworded.
To use the Pro features though you need to run Custom Clean and not Health Check. Health Check is a simpler clean and is meant for less technical people. - You do need a bit more computer knowledge to use the pro features.
Thank you
