Dennis, what a memory. Most impressive. Thanks for those links, old memories, eh?
And you are quite right, its a looong topic. I very much appreciate the kind help so far. I had no idea that the
thread would run so long, and certainly don’t want to be a bore. But I find this investigation intriguing. I’m
just thinking that maybe some other hapless windows xp user is having a similar problem and will maybe stumble on
this. Probably not, probably they have all gone over to the dark side, win 10. ![:)]()
To make it easier, here is a summary:
The computer just sort of locks up.
Sometimes once or twice a day, sometimes not for weeks at a time.
the lockup usually occurs when awakening the computer from standby, then getting on the net.
When it occurs, the desktop window and the system tray stop responding to the mouse or keyboard.
— but Process Explorer and HWmonitor still respond normally …
— except if you try to get them to do something outside their own window, such as shut down the computer.
Sometimes after a restart check disk runs, always on D: (recovery partition), always no bad sectors.
The mouse and keyboard are OEM, PS2 type, the graphics processor is integrated in the MB
what has been done so far:
There is a screenshot of some tests actually running in post #51
ran chkdsk and sfc /scannow, OK.
ran avast boot scan, OK.
Manually deleted the recycle bins in safe mode, OK.
monitoring w/ procexp and hwmon for heat, CPU, RAM use, OK.
ran speccy for heat & CPU, OK
ran intelburntest, got hot, 147 deg f, but didn’t lock or freeze.
ran gsmartcontrol, the 2 minute test, attributes and health report were OK.
ran HDTune, no bad sectors, health report looked OK.
ran cleanmem, made no difference.
ran mta’s touch test, sort of hot but no blisters. ![:)]()
what has not been done yet:
replace the CMOS battery
run Microsoft Windows Memory Diagnostic
run Puppy for 2 or 3 days to see if lockup occurs
replace firewall or AV. Firewall is now the chief suspect.
use a non PS2 mouse and keyboard.
check hardware contacts for oxide, do a thorough cleaning.
run that static discharge test
Recent observations & actions:
- Dennis, the lockup did occur on xp on the newer computer.
— It dual boots 7 and xp from different HDDs using the BIOS boot menu.
- the lockup seems to correspond with Avast automatic updates. . .but,
— At that same time acs.exe, an outpost process, jumps to near top of the CPU usage list.
Avast will run a “loop scan” ?? every 3 days. This corresponds roughly to the recent frequency of the lockups. So
I’m thinking, the locked window is the desktop and systray, maybe it’s that Avast setting?
It’s 99.9 percent sure that hardware / heat isn’t the problem.
Its also 99.9 percent sure the problem is with Outpost, especially since popup that appeared. Declining that popup may
have fixed it. But if the lockup occurs again, I intend to first shut off that 3 day setting in Avast, then if
need be replace outpost, then if need be replace Avast.
Any other suggestions?
