Not sure if a hard drive error could be the problem here. If so, it might be the same on the newer computer because HP shipped it with a faulty HDD, and when the tech fixed it under warranty he didn't replace it, probably just ran chkdsk
Just ran gsmartcontrol 2 minute test. Not sure I like that stuff about Old_age, and Pre-fail. ![:P]()
Results:
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Caviar Blue EIDE
Device Model: WDC WD2500AAJB-00J3A0
Serial Number:
LU WWN Device Id:
Firmware Version: 01.03E01
User Capacity: 250,059,350,016 bytes [250 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is:
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1
3 Spin_Up_Time 0x0027 144 136 021 Pre-fail Always - 3758
4 Start_Stop_Count 0x0032 091 091 000 Old_age Always - 9328
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 076 076 000 Old_age Always - 18033
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 091 091 000 Old_age Always - 9266
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 237
193 Load_Cycle_Count 0x0032 197 197 000 Old_age Always - 9329
194 Temperature_Celsius 0x0022 109 099 000 Old_age Always - 34
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
1 Short offline Completed without error 00% 18033 -
2 Short offline Completed without error 00% 14822 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
