Hi!
Can anyone please tell me whether my HDD is failing.
I ran the Speccy and the "S.M.A.R.T Status : Warning" appeared.
Below is the entire generated report by Speccy:
Storage
Hard drives
WDC WD7500BPVT-24HXZT3
Manufacturer Western Digital
Form Factor GB/2.5-inch
Heads 16
Cylinders 1,453,521
Tracks 23,256,336
Sectors 1,465,149,168
SATA type SATA-II 3.0Gb/s
Device type Fixed
ATA Standard ATA8-ACS
Serial Number WD-WXF1E81PULX9
Firmware Version Number 03.01A03
LBA Size 48-bit LBA
Power On Count 2028 times
Power On Time 223.1 days
Speed 5400 RPM
Features S.M.A.R.T., APM, NCQ
Max. Transfer Mode SATA II 3.0Gb/s
Used Transfer Mode SATA II 3.0Gb/s
Interface SATA
Capacity 698 GB
Real size 750,156,374,016 bytes
RAID Type None
S.M.A.R.T
Status Warning
Temperature 40 °C
Temperature Range OK (less than 50 °C)
S.M.A.R.T attributes
Partition 0
Partition ID Disk #0, Partition #0
File System NTFS
Volume Serial Number AE4FE3BB
Size 199 MB
Used Space 32.1 MB (16%)
Free Space 167 MB (84%)
Partition 1
Partition ID Disk #0, Partition #1
Disk Letter C:
File System NTFS
Volume Serial Number D651EF44
Size 654 GB
Used Space 90 GB (13%)
Free Space 564 GB (87%)
Partition 2
Partition ID Disk #0, Partition #2
Disk Letter D:
File System NTFS
Volume Serial Number 52928110
Size 29 GB
Used Space 2.33 GB (8%)
Free Space 26.7 GB (92%)
Partition 3
Partition ID Disk #0, Partition #3
Size 14.7 GB
