Hard Drive Error after running CCleaner on 35 passes
Hi I just registered to ask this question. I deleted a disk image of Wolfenstein with 35 passes and now my hard drive space is reading that I only have 699 MB's of free space. I know this is false because before I ran the cleaner I had 80+ GB of free space on my hard disk.
This has happened to me once before, but running the cleaner again fixed the problem, I've tried running it multiple times after the error and it is still displaying I have very little storage space left on my hard disk, is there any way to resolve this?
Possibly the lost HDD space is in System Restore Points.
I have one restore point that I made today, after the error. No dice, any other suggestions?
OKay if it makes a difference I'm using windows seven and I have a 250 GB HD and i should have about 129 gigs free on it.
Did you run the Wipe Free Space feature of CCleaner?
If so, look for a large file at the root of your operating system with a long alpha numeric name.
When the process is interrupted, the file is not deleted. I believe this has been corrected in more current versions of CCleaner.
I found the problem it was a file called $recyclebin or something, hidden. I deleted it and everything is fine.
No I didn't wipe free space
