Should I follow Andavari's suggestions? I did a clean install a week ago (I think it's been a full week).
CHKDSK certainly won't hurt anything, but I doubt it will fix anything for you, since you have already proven CCleaner is your problem.
Even if you do reap any benefits, it won't be anything close to a whole minute knocked off your boot time. Actually, defragging might be more beneficial than running a disk scan, assuming you have done quite a bit of installing and recopying files to your fresh new install of Windows.
Run CHKDSK first, just in case your HD has any physical errors. That way, Defrag doesn't try to use any damaged sections of the disk. After you do that, run CCleaner, and then, finish off with a disk defragment, and see if your booting time goes down any. Just don't expect anything too dramatic!
I did defrag recently, and already analyzed again today (just to be sure)...but it doesn't need to be defragged. I'll run the chkdsk now.
Everthing came out clean. 0 errors, and what not. Did the Process Idle Tasks thing. Defragged, and I think that the startup was a little faster but I haven't timed it yet to see by how much (or if at all for that matter).
Rriddgley.....are you going to split this thread? It's completely hijacked! Thanks.
