does anyone know of a good sound editor? one that would display the diffrent frequencies so i could take out sounds i dont want in a clip. also, that can strip the sound off of a video. Thanks
Check out these two. They can edit audio, but I'm not sure about ripping it from video but it's worth a shot.
Audacity
http://audacity.sourceforge.net/
Wave Pad
http://www.nch.com.au/wavepad/
Also you might find something you like better on this site.
http://www.download.com/Audio-Production/3...-0.html?tag=dir
Well see, i need to take the audio from a video and then edit the audio. I dont really want to play through my speakers and record it through my mike, its already worse enough quality! so somehow i need to rip the audio off of my video that i have.
Ok, I did some searching and I think I found an easier and better tool for you. All you should have to do is select the video file and this program should make a seperate mp3 file. You could then use one of the above programs to edit the audio. Go to the below link and look at the first program.
THANK YOU SO MUCH!!!!!!!!!!!! that was pretty nice of you, i really apprieciate it
)corjello(
Happy to help. Let me know how that program goes.
that sound ripper was a very good program, you should add it to the freeware sticky. It was clean and simple, yet it had a good amount of options
