The Thumbnails from GIMP (in XP C:\Documents and Settings\.thumbnails) useing much storage after some work with picture.
Can you please add a function to delte these little images?
Thanks
Thanks
Hi Mickel, and welcome to Piriform.
If you download and place CCleaners Winapp2.ini in the CCleaner "Program Files" folder, you'll find that particular area is covered.
http://forum.piriform.com/index.php?showtopic=1110 (Zip download at the end of first post)
Once in place, when you next open CCleaner, you'll find some new asterisked items showing under "Applications". These are the Winapp2.ini entries.
Hope that helps.
Thanks DennisD
and sorry for my bad english ::. i come from austria
Thanks DennisD
Mickel, you're English is a lot better than my Austrian, so no apology needed.
