Get Newsletter not possible
In the past i got a newsletter from your page when ccleaner gots updates, only cclenaer.
Then i delete because i change my mail and wont it back, but i cant register to the newsletter.
I got no captcha or something like that:
Please help me...
Greetings by Gongedulations
Try again. Page loads good for me, captcha and all, should work for you.
Works for me too, but I've seen page load problems like that on other websites caused by video drivers and/or problems with java. Captcha uses javascript. Just a thought. ;)
Here's the Java test page.
Java and JavaScript are two different things, so no Java isn’t needed for signing up for the newsletter. However to use most websites JavaScript in your web browser(s) may or will need to be enabled.
THX guys.
I used another pc and i got the captcha in this firefox browser.
So, i have to check now, what went wrong with my browser at my home.
Another question i have:
Where can i get the newsletter only for ccleaner, i dont want to get informations about the other product.
Greetings Gongedulations
Something to check out:
1. In Firefox click "Tools -> Options -> Content (tab)", then make sure "Enable JavaScript" is ticked.
2. In Firefox click "Tools -> Options -> Privacy (tab)", then click the "Exceptions... (button)" and make sure you're not blocking cookies from being set by piriform.com and www.piriform.com
3. If you use an adblocker in Firefox such as Adblock Plus make sure there's nothing in there blocking piriform.com and www.piriform.com
4. If you use the Firefox addon/extension/plugin NoScript make sure you allow scripts to work with piriform.com and www.piriform.com
