If a film is split into a number of parts by winrar, you need all the parts to recombine the film. It is called a split volume. Each part is not playable or extractable in itself.
The error message your seeing is because you do not have all the parts necessary. So if you have only parts 1 to 9 of a film that was split into 10 parts, there is no way you will be able to view the film - a large chunk of the film is missing.
If you have "part 7" on your hard drive, click browse and locate it manually - the software does occasionally get confused. If you don't have "part 7" you will need to go back to the source of the files and find it.
Bear in mind you can split a file in to any number of different parts of all sizes. It is likely that you will need part 8 or maybe even upto part 50 and beyond- either way you need ALL the parts.
Also make sure all the parts are in the same folder.
Exactly! That's why the error is popping up because it expects that part to be available and it isn't.
It's really not that much different than for instance creating a WinZip Self-Extractor installation that spans onto two floppy disks, of course without floppy disk #2 extraction would fail.
