First of all CCleaner is a great software.The feature I want is to choose what to erase at startup.For example Recycle bin needs another look before cleaning and not at startup.This way the software becomes more user friendly.Thanks.
Hi nagan, and welcome to the forum.
It sounds like you installed CCleaner with all the options checked, i.e. "Run at Startup", "Add run CCleaner option to the Recycle Bin context menu".
If that's the case, you can go into CCleaner > Option > Settings, and uncheck those options, which means you can launch CCleaner manually at a time of your choice. This obviously gives you control of whats removed or not.
Hope this helps.
