Freezing at 26%
Hi,
I'm new to the forum but have been using CC for a couple of years.
I have updated to version 2.34.1200 but I have found that it works fine one time after installation, but subsequently it "freezes" at 26% cleaned when cleaning my recycling bin. The blue circle keeps spinning, but the progress bar moves no further. The recycle bin appears to have been cleaned, but anything after that remains.
I am running Windows 7 64 bit.
Hi Glypex, and welcome to the forum.
It could be a file in the Recycle Bin, or the "Recycler" itself causing the problem. Deleting the Recycler will usually fix it, as Windows will create a new one when you reboot your PC.
Instructions here:
Windows will make a new one.
Hope that helps.
Thanks Dennis, your much appreciated help seems to have sorted out my problem. Many thanks indeed.
