the program is awesome, but one more thing that would make it the supreme utility is if it had a freespace cleaner or eraser
If you want secure file slack cleaning, then maybe you should use a software that was created for that purpose.
Perhaps Eraser can do that?
Get Eraser 5.7
5.8 is still BETA and appears to still have issues.
