fragment size in options sets KB, not MB
I didn't see this posted before, but it is an easy bug to fix. Under settings, options, quick defrag tab, using custom rules, if you set a size for "Have fragments smaller than:", by a little testing, the value is used as KB, while the label by the box says MB. I have it set to 1000, and it still defrags nearly all files (the vast majority of which are far less than a GB).
