Force quitting edge
CCleaner gives an option for force quitting edge, but this reflects badly in the Reliability Monitor control panel;
perhaps there is a way to avoid this?
Disable Microsoft Edge pre-loading and that might fix it (referring to the original Edge not the upcoming replacement based upon Chrome/Chromium):
https://forum.piriform.com/topic/56335-solution-ccleaner-cannot-fully-clean-microsoft-edge-due-to-pre-loading/
Edit:
You shouldn't allow it to force Edge to close, doing that can cause the database in Edge to become corrupted.
Good point, many thanks.
