For TwistedMetal
Hi TwistedMetal
thanks for your update to winapp2 from 22/7/07, sorry this is a bit late. I've been using uTorrent for about a year now ( i think its the best torrent client) and when i updated my winapp2 file CC listed uTorrent under apps>internet as it should. After my first clean i expected CC to show quite a lot of uTorrent related things, but it showed absolutely nothing and it never has, its as if it has now listed uTorrent but its not cleaning anything from it. I remember the problem we had when i asked you to add Limewire, which you did, that took a bit of sorting. Could you please check this out (did you test it on a installed version on your system). I appreciate all the help you give as i don't understand enough about computers to make my own custom entries, thanks again
Richard...
Are you there !!!
First, Be patient. If you really wanted to talk to TM you should have PM'd him.
Second, if you look at the WinApp2 entry:
[*uTorrent]LangSecRef=3022DetectFile=%ProgramFiles%\uTorrent\uTorrent.exeDefault=TrueFileKey1=%ProgramFiles%\uTorrent|*.dmp
You will notice that it only is meant to clean .dmp files, which I assume are crash files. Meaning they are only there if/when uTorrent crashes.
I did read this thread and forgot about it. I will see what I can do, my test pc right now is not running. So I will have to take it apart and fix it.
Thanks TM, i didn't mean to be pushy and mushu13 if i knew as much about computers as you i wouldn't have to ask would i.
Hi TM, any luck yet...
