Have a look at CCleaner\Applications\Multimedia, and make sure Adobe Flash Player is checked.
There are also two locations containing Flash Cookies which CCleaner hasn't been picking up:
C:\Documents and Settings\<username>\Application Data\Macromedia\Flash Player\macromedia.com\support\flashplayer\sys
and...
C:\Documents and Settings\<username>\Application Data\Macromedia\Flash Player\#SharedObjects\Z4PLHKBB
There's a new version of CCleaner out today which I haven't installed and tried yet, which may now clean these areas, but I'm posting this FYI in case it doesn't.
You could then add these locations to CCleaners "Include" feature. Making sure to check the "Custom Files And Folders" box in "CCleaner\Windows\Advanced".
Yes I don't disagree but surely the essence of CCleaner is that it's easy to use 'one click' - the analogy is to locate every browser cache location and to add them all to custom files and folders so I still think it's an important feature addition because most users are probably unaware that without some settings tweaks traces of user activity are still retained
p.s. C:\Documents and Settings\<username>\Application Data\Macromedia\Flash Player\#SharedObjects\Z4PLHKBB is specific to your machine - mine is J3S7H5ZE
Hi Nick, and welcome to Piriform.
and...
Locations of cookies are changing with almost every update of the various browsers, which is evident by the many current and recent discussions on here.
The suggestion to use the "Include" feature was made in an effort to help you maintain your privacy until the developers of CCleaner catch up with these constant changes.
I am aware that this is a "salted" number, a security feature, but it would have been pretty difficult including anyone's but my own as a guide to the correct location.
but I knew how to do it - this post is in Suggestions category, not 'er how do I' category
the only ones it does not clean are those I have added to the exclude list.
However if you want to remove the Most recent list add this to your winapp2.ini
[*Adobe Flash Most recent Files]LangSecRef=3023Detect=HKCU\Software\Macromedia\FlashPlayerDefault=TrueRegKey1=HKCU\Software\Macromedia\FlashPlayer
Note: I HAVE tested this Winapp2.ini entry and it functions as I said. the next flash site you go to will restore the now empty HKCU\Software\Macromedia\FlashPlayer without any recent in it
So I'll do some more testing but unless the developers of CCleaner can think of a better way the only way to dump these websites is to delete the entire settings.sol file (which will recreate itself on the next flash site run) but will also delete all other flash settings (default camera, Autoupdate timing, Autoupdate last check, trusted/untrusted)
If these concessions are okay with you I can edit the above winapp2.ini and you'll be good to go.
Note I would NOT recommend manually editing this file however as any editing seemed to make Flash recreate the settings.sol anew thus losing any settings anyway
Thanks, I'm _very_ pleased that you have confirmed it
I think it's a serious issue that should be highlighted
Do you know how it can be brought to the attention of the people at Piriform because I'm convinced they would want to know so they can make their excellent product even better?
Thanks again
Nick A
Yup, you are correct this did suprise me
So after this revelation I ran a Regshot and snapped the registry and C:\ before and after pressing the clear all site list
Then did a couple more experiments and found that these sites are stored in the
