Adobe has issued a fix to address a crash in the flashplayer updater service.
Not available yet on main page but available on Adobe page here.
If you have Flash auto updater turned on you should get the fix within next 24 hours.
(I check manually for Flash updates so am not affected)
http://forums.adobe.com/message/4594596#4594596
what if you get the crash while trying to update to the fixed updater? ![:lol:]()
Nergal
3
now that I'm using Secunia's latest version of PSI I turned off flash's new updater service
Corona
4
I always disable Flashs' auto update.
I always nuke the whole service off my system.
Since of course I know there's going to be an update in about one months time anyways.
