Flash Player cleaning option gone
Hi, long time user without problem.
I noticed yesterday that the option to clean Adobe Flash Player was missing from the multimedia section. I have tried reinstalling CCleaner without success. I did update to the latest version of flash player day before yesterday and am wondering if that may be the problem?
WinXP SP3
CCleaner 2.26.1050
flash player 10.0.42.34
Thanks
I updated flash player as well but mine is still listed in ccleaner.
Did you uninstall the previous version of flash first? Did you update both flash for IE plus any other browser you use as well?
uninstall you flash player here,and install the lastest version again.maybe you failed to update you flashplayer
OK...uninstalled flashplayer and separately reinstalled to Firefox and IE.
All is well now.
Thanks for the help
Glad things are sorted for you now jramone53 :)
Hi. I'm having the same problem.
CCleaner is not picking up the new version of the flash player plugin.
I've uninstalled and reinstalled the player and the only fix I've found is installing the IE version.
WinXP SP3
CCleaner 2.26.1050
flash player plugin 10.0.42.34
