Most of you may have noticed the security alerts over the last few days concerning PDF files with Flash content. Adobe has now released the long awaited Flash Player 10.1, which fixes the vulnerability.
It is recommended to uninstall all previous Flash Player versions (download uninstaller). All browser windows should be closed when the uninstaller runs.
Make sure to uncheck any unwanted software offers during the installation.
I think FileHippo.com is better when it comes to Flash updates. You can get the installer without Adobe DLM, McAfee nonsense, or Google toolbar
I agree, although you still have to get the Uninstaller from Adobe which doesn't offer to install any bundled stuff. I do like how they've re-did their installer, it looks nice.
Is anyone else seeing a notable decreased in performance with Flash 10.1?
I thought this new version was suppose so improve performance and add hardware acceleration for HD videos, but I'm actually getting worse performance on youtube than before.
Since it fixes tens of critical security flaws, I'm afraid you'll have to update soon
I run sandboxed on Windows so I will update when the update is stable.
I have lost count how many "critical security flaws" that have been reported over the years in programs I use or OS I use yet I never get malware. Smart use of the computer and avoiding internet garbage will go a long way to keeping your machine clean. The critical flaws are a big problem for the risky web surfers. I'm not saying to not patch your system but make sure the patch is stable and doesn't cause more problems than it supposed to prevent.
