Flash cookies
Hi,
I came to know that there are "flash cookies", here there is an explanation: http://www.wired.com/epicenter/2009/08/you...es-think-again/
Then I thought, "well, I have CCleaner".
I wondered if it really deletes those cookies, and I found this thread: http://forum.piriform.com/index.php?showtopic=16139
Reading there, seemingly CCleaner deletes such cookies.
I have "Adobe Flash Player" checked under "programs" and I run CCleaner frequently.
But then I found this page: http://www.macromedia.com/support/document..._manager06.html
And I could see that I had a lot of Flash cookies even from sites that I don't visit from long time ago.
So, my suggestion, is to add the capability to CCleaaner to also delete "Flash cookies".
Thanks.
argen
Hey your right it didn't clean those...
I second this.
If I'm not mistaken it is relatively new that CCleaner has begun to take some of these Flash cookies out. And staff is expanding this feature, I think. So have patience...
<_< Ref: Flash Cookies
:rolleyes: In "Options -> Include" there should be an option to generally add *\sol without the obligation to give a path! Then all Flash Cookies will be deleted when running CCleaner!
:D Cheers,
sweidre
