Flash Cookie Cleaner
Is having a flash cookie cleaner a good thing?
I noticed today this site:
http://www.flashcookiecleaner.com/
If this is a good idea, will CCleaner possibly implement a feature in the future?
THANKS
think ccleaner has it
Has it, doesn't clean it :-(
[Adobe Flash Player]ID=2055LangSecRef=3023Detect=HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}Default=TrueSpecialKey1=N_FLASH_COOKIES
However Flash Cookies (As defined by my Internet cleaner program iePrivacykeeper) are here (Which is untouched) C:\Users\{USERNAME}\AppData\Roaming\Macromedia\Flash Player\#SharedObjects\{IndividualKeywhichchangesperFlashinstall}
If someone can help me with Recurses
we could make a clean that does %appdata%\Macromedia\Flash Player\#SharedObjects\
dammmm..just used it....it did the job..thanks for the link..dasfox
hope ccleaner look into it.
but wait...it not only takes the flashcookies...
it takes the cookies to loginto the sites...that's bad.....really bad..
Flash cookies are used by some sites to store login info the same as regular cookies
ok i see...that's why it said it as domain cookies....thanks..is good for a really deep cleaning of cookies too.
