[Fixed in 5.89.9401] CCleaner 5.89.9385 immediately closes on launch
I think I know what the problem is. If I am connected to the internet CC closes immediately. If I am not connected to the internet CC does NOT close immediately. It must have something to do app when it connects to the internet.
Mike
I am having the exact same problem.
Tim
Me too
Same problem - win 7 - 64 - up to date - CCleaner pro
Same problem too! Win 10 64 CCleaner Pro plus! Paid subscription!!
Same problem ---Win 8.1 CCleaner Pro Plus---Please Fix asap!
Since the cleaner closes immediately on open... how do we update it when a fix comes out? When are you going to let the community know what is going on and what to do about it? Thank you!
I have the same problem, except I am using Windows 10
2 hours ago, harwich said:
		Mike
I agree with Harwich. This is the work-around steps I'm using until such time the latest version of CCleaner is fixed:
Step 1 - Disconnect from the Internet.
Step 2 - Open CCleaner. It should stay open at this point.
Step 3 - Reconnect to the Internet and run whatever sub-program(s) within CCleaner you want.
Windows 10 Pro Version 21H2
CCleaner - The latest version to date.
Are all of you using health check, or are some using custom clean
See here
Support asking for debug reports
I am using health check
Stesso problema su 2 PC su 3. L'unico sul quale funziona ha windows 7 pro, invece negli altri 2 con win 10 pro e win 11 home si apre e si richiude immediatamente
I'm having the same problem both with my HP pc with Windows 11 and my fix pc with windows 10. I tried to disinstall and reactivate the ccleaner program but no benefits. The problem is still there. Are there possible solutions to this problem???
I am having the same problem. Crashes as soon as it opens. Seems that the new version has a bug. How do you contact Ccleaner to report the problem. I can not find an email address or phone number on the web site.
I don't health check and am having the same problem
Not sure if just me..after most recent update, CCleaner shuts down. I try to access the program but it keeps shutting down. Reinstalled it and same issue. Went to my windows 10 backup to have original install of ccleaner now it was fine. Then, did the CCleaner update again, and the cleaner program shuts down will not work.
1 hour ago, Keith O said:
support@ccleaner.com
Me to
custom clean
