fix registry issues
;) Hi all,
I run CCleaner this morning and I found 218 registry issues in registry integrity section. Is is safe to delete all issues without back up the registry ?
Thank for your suggestions
wishes,
Hello abu :)
A read here may give you some tips.
http://www.internetrotsyourbrain.com/ccleanerbeginnersguide/
A brief explaination is when you do an issues scan and choose to fix, you are offered the choice of saving those entries. They are saved by default in my documents, look like a piece of paper with blue blocks on and be called someting like cc_ 20080425.reg (todays date).
If you had problems after removing the entries just right click on the backup and choose merge.
cant use ADOBE READER 8 LINK WAS LOST AFTER USEING CC CLEANER
Hello abu :)
HOW DO U RESTORE LOST DATA, THAT WAS REMOVE IN CC CLEANER?
Did you lose it after an issues scan?
Have you tried system restore?
