Hi,
I’m struggling to find answers in simple terms that I can understand. I have identified two files on my Samsung 850 EVO SSD (C:) and another two files on my HDD (E:) that I want to delete without being recoverable. I don’t want to wipe the drives entirely.
After some reading it seems that erasing files from an SSD is difficult, but I’m not clear on what is possible in terms of erasing and what is left behind. Also, I assume the recycle bin is located on my C: drive, so are files that are deleted from my HDD (E:) copied to my SSD (C:) during recycling?
Also what problems might there be with Windows File Recovery keeping copies?
Thanks.
if you want to permanently erase a file, the way that is done is by overwriting the file, which is not the same as deleting the file, so a file that has been overwritten would not be moved to the recycle bin.
i use "sdelete" (the 64-bit version) to overwrite files that i want permanently erased:
https://docs.microsoft.com/en-us/sysinternals/downloads/sdelete
pretty much, just follow the simple instructions. however, in my experience, i was only able to get sdelete to overwrite files, not whole folders.
you can use the "cd" command to change folders, to get to where the file is located. for example "cd C:\Users\(user)\Documents"
2 hours ago, redwolfe_98 said:
Microsoft Sysinternals SDelete while useful can be a complete disaster for some people and especially if the commands are inputted incorrectly, therefore I warn against using a non-gui tool for secure erasing files.
Delete the file (Shift+Delete) so that it doesn't get sent to the Recycle Bin, then run TRIM on the SSD using Windows built-in Optimize Drives.
Each drive has it's own unique Recycle Bin, if you delete a file on any drive that Windows will create a Recycle Bin for it does not move it into your C: Drive Recycle Bin.
If you have a duplicate of that file on a HDD you could delete the file to the Recycle Bin, then enable Secure Delete 1-Pass in CCleaner, then on the left side of CCleaner right-click the Recycle Bin and select 'Clean Empty Recycle Bin' and it will overwrite the files in any Recycle Bin on the system. Remember to disable Secure Delete in CCleaner so that it doesn't take forever to delete files and so that it isn't being ran on your SSD.
Files deleted from a SSD are usually not recoverable. (unless they are still in the recycle bin).
You'll see in the Recuva sub-forum that it's often stated that you can't recover files from a SSD that has TRIM enabled.
https://www.stellarinfo.com/blog/myths-about-disk-wiping-and-solid-state-drives/
Quote
The SSDs use a different mechanism to store data than mechanical hard drives, and thus function differently. When you delete a file on your SSD, a TRIM command is issued to the drive by the operating system. This results in permanent erasure of the file contents from the SSD. Hence, a simple delete operation will clean data off your SSD. You do not require wiping the SSD using disk wipe utilities.
A bit more technical about TRIM and data recovery from SSDs:
https://www.cleverfiles.com/howto/ssd-data-recovery.html
Quote
TRIM is an Advanced Technology Attachment command that makes it possible for an operating system to inform an SSD which blocks of data are no longer considered in use and can be wiped internally. TRIM is very helpful for the long term functionality of SSDs. However, when TRIM is used, data recovery software isn’t capable of functioning properly.
Thank you for all the replies.
15 hours ago, Andavari said:
How do I manually run TRIM on the SSD?
with windows 10, the way that i do it, click the "start" button to open the menu there. then go to "windows administrative tools." then, within the "windows administrative tools" folder, click "defragment and optimize drives." you can run "trim" from there.
Or slightly quicker:
1. Cortana/Search, then paste/type in: optimize drives
2. In Optimize Drives select the SSD so that it's highlighted, and then click Optimize.
I've just noticed on 'Optimize Drives' there is both 'C': and 'System Reserved' listed as SSD. Do I TRIM both of these?
