Even CC can't help ... can you? I have a file ... 1123386181-13491 ... 0 kb's ...located in my documents ... it may have been an original .jpg file I deleted months ago and this number remained and has become a problem in the last 6 weeks ... it will not delete, it will not copy, paste or go to the recycle bin. When running CC the message desplayed states "Cannot delete the specified file make sure you specify the correct path and filename and gives the code 1117864622-87011. -- When trying to open the file --open with gives two primary options ... my photo viewer or MS Publisher ... I've done a few searches ... tried a few fixes but with no result ... Anyone ever have a file (empty at that) that Won't delete???? Sure would like your imput.
thanks
dave
