When I select Find File and search for duplicates, in the resulting list I select a .jpg entry and right click on "Select All of Type" and it only ticks one in the list and their are hundreds more .jpg.
I have tested this on my v4.16.7643 and all seems to work.
What I have done is, right click on the file name and click on "Select All of Type" this checked all files with the same file extention excluding one within the same group of duplicate files.
Note: File Finder is still in debate with some users on the forum, it has a lot of bugs and false hits. So make sure you manually check some of the files.
