Greetings,
I tried out CCleaner today and after rebooting my machine no file extensions work. So I cannot open files or run .exes or do anything else. How can I fix this?
thanks
Greetings,
thanks
Hello dlo, and welcome to the forum.
What version of CCleaner are you using?
What operating system are you using, and is it 32-bit or 64-bit?
Did you run the cleaner, and fix issues in the registry?
Hello,
I downloaded and ran the latest version of CCleaner. I am using XP/SP2. I didn't realize that Cleaner would get rid of a lot of the file associations. I backed up the registry before running Cleaner. I merged that backup but that hasn't fixed the problem. I did reassociate some of the file extensions, like .exe but what I really want to do is restore the registry to prior to CCleaner or find some other way to quickly reassociate all the file extensions, .lnk, etc.
thanks if you can offer any suggestions.
Can you do a system restore to before you lost the file associations?
I restored the registry and that has worked once I rebooted. I will have to do some research to see if other problems exist. That and read about CCleaner before using it again.
Thanks!
Glad you got it sorted out.
I use Erunt to backup the registry and highly recommend it.
http://www.larshederer.homepage.t-online.de/erunt/
See the link below for the CCleaner Guide.
