After installing Ff 7 I was told that it no longer uses Java.
Can I uninstall Java or is it needed by other apps, some sites need IE...
Thanks
Thanks
Some here at this site uninstalled Java. I have as well. That was about 6 months ago. So far I've run into maybe one site that had a Java-run app or whatever that I couldn't access without Java. You know what? I think Java is bloatware. It's not worth it. Like QuickTime, developers are dropping it.
The only reason I keep Java around is for minecraft!
Yeah but you think fezzes are cool.
No hurt. Just funning.
Because of my present location, I have to watch p2p broadcasts from the other side of the planet. Will it interfere with those?
If you uninstall Java and things don't work for you, you can always re-install it.
https://www.youtube.com/watch?v=bvWYw0CnuSI
I think Java is still needed, at least I need it alot.
It still uses/can use Java, like said before, if you uninstall it, Java-based webpages/apps/games won't work.
Thank you all, I have uninstalled it now, and as far as I can tell, everything seems to be working...
